HP EliteBook 8770w Mobile Workstation is designed to meet the military standard Mil-Std-810G for drop, vibration, dust, altitude, and high temperature operation with Intel Core i7 with vPro and Core i5 with vPro technology (optional).
Feature
Processor
Mobile Intel QM77 Express
Graphics
Internal:
External:
Up to 32-bit per pixel color depth
DisplayPort:
Supports resolutions up to 2560 x 1600, 30-bit color depth at 60 Hz, and full HD (1920 x 1080) monitors, 24-bit color depth at 120 Hz
VGA:
Port supports resolutions up to 2048 x 1536 at 75 Hz, and lower resolutions at up to 100 Hz
DVI-D (single link):
Video signal available through DVI port in optional HP Docking Station (sold separately)
supports resolutions up to 1600 x 1200 at both full and reduced blanking, and 1920 x 1200 at reduced blanking
Flash cache module
Optional 24GB mSATA Flash cache module support for Intel Smart Response Technology. (Available only with standard non-SED hard drive. )
Storage and drives
Hard drives:
The hard drive is mounted directly to the notebook frame, reducing the transmission of shock to the hard drive. Uses three-axis digital motion detection with intelligent sensitivity to help protect the hard drive during normal use from shock and vibration. The digital accelerometer temporarily halts all data transfer and parks the hard drive when abrupt motion is detected.
Solid State Drive (SSD):
Optical drive
Fixed 12.7 mm SATA optical drive:
Second/Third hard drive:
Memory
Standard:
Maximum:
Dual-channel:
Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots.
Networking/Communications
Wireless:
Support for a broad range of secure, integrated wireless LAN and wireless WAN options featuring support for the latest industry standards. Broadband Wireless (WWAN) requires a Windows operating system and is available in select countries as a standard, factory configurable feature only. Integrated Bluetooth is also available (factory configurable only) and can be combined with any of the supported wireless LAN and wireless WAN options.
Broadband Wireless (WWAN):
Integrated wireless LAN options:
Communications:
Audio
Optional 720p HD webcam
Power
Power supply:
Primary battery:
Secondary battery
System standby time:
Up to 1 week
Power conservation:
Feature
Stand-alone power requirements (AC power)
Nominal operating voltage
19.5 V
Average operating power
45 W
Maximum operating power
<200 W or <230 W
Temperature
Operating
0° to 35°C (32° to 95°F) (not writing optical)
5° to 35°C (41° to 95°F) (writing optical)
Non-operating
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating
10% to 90%, non-condensing
Non-operating
5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating
40 G, 2 ms, half-sine
Non-operating
200 G, 2 ms, half-sine
Random vibration
Operating
0.75 grms
Non-operating
1.50 grms
Altitude (unpressurized)
Operating
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating
-15.24 to 12,192 m (-50 to 40,000 ft)
Dimensions (W x H)
38.2 x 21.5 cm (15.0 x 8.5 in)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
300 nit typical
Pixel resolution
Backlight
LED
PPI
107
Viewing angle
±60° Horizontal, ±50° Vertical (minimum)
60/60/50/50 (Left/Right/Down/Up) (minimum)
Dimensions (W x H)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typ)
Pixel resolution
Backlight
LED
PPI
127
Viewing angle
±160° Horizontal, ±160° Vertical (minimum)
80/80/80/80 (Left/Right/Down/Up) (min)
Technology type
30-bit In-Plane Switching (IPS)
Color depth
10-bits/color
Display colors
Over 1 billion colors (native mode)
Color gamut coverage
Dimensions (W x H)
Diagonal size
43.9 cm (17.3 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typ)
Pixel resolution
Backlight
LED
PPI
127
PPI
118 ppi
Viewing angle
±60° Horizontal, ± 50° Vertical (minimum) or
±70° Horizontal, ±60° Vertical (typical)
Internal storage
750GB 7200 rpm SATA hard drive
500GB 7200 rpm
SATA hard drive
320GB 7200 rpm
SATA hard drive
500GB 7200 rpm SMART SATA II Self Encrypting Drive
SATA 6 Gb/s 256GB, 2.5-inch SATA SED Solid State Drive (SSD)
SATA 6 Gb/s 180GB, 2.5-inch Solid State Drive (SSD)
SATA 6 Gb/s 128GB, 2.5-inch Solid State Drive (SSD)
Drive weight
101 g (0.22 lb)
115 g (0.25 lb)
115 g (0.25 lb)
115 g (0.25 lb)
73 g (0.16 lb)
78 g (.171 lb)
73 g (0.16 lb)
Capacity
750GB
500GB
320GB
500GB
256GB
180GB
128GB
Height
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
7 mm (0.276 in)
7 mm (0.276 in)
7 mm (0.276 in)
Width
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
63.5 mm (2.50 in)
70 mm (2.76 in)
70 mm (2.76 in)
70 mm (2.76 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
SATA 3 (6 Gb/s)
SATA Gen 3 (6 Gb/s)
SATA 3 (6 Gb/s)
Transfer rate - Synchronous (maximum)
300 MB/s (drive capability)
Maximum sequential write: Up to 460 MB/s
Maximum sequential write: 550 MB/s
Maximum sequential write: 415 MB/s
Seek time
(typical reads, including settling)
Maximum sequential read: Up to 260 MB/s
Maximum sequential read: 520 MB/s
Maximum sequential read: 175 MB/s
Rotational speed
7200 rpm
7200 rpm
7200 rpm
7200 rpm
Logical blocks
1,465,149,168
976,773,168
625,142,448
976,773,168
500,118,192
351,651,888
250,069,680
Operating temperature
0° to 60°C (32° to 140°F) [case temp]
0° to 70°C (32° to 158°F) [case temp]
Features
ATA security
ATA security
ATA security
ATA security
Feature
DVD-ROM Drive
DVD+/-RW SuperMulti DL drive
Blu-ray ROM DVD+/-RW SuperMulti DL drive
Blu-ray R/RE DVD+/-RW SuperMulti DL Drive
Access times
Random
Random
Random
Random
Max data transfer rate
Transfer mode
UDMA Mode 5
UDMA Mode 5
UDMA Mode 5
UDMA Mode 5
Interface
Gen 1 SATA
Gen 1 SATA
Gen 1 SATA
Gen 1 SATA
Supported media (read)
CD-DA, CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW, DVD-RAM
CD-DA, , CD-TEXT, CD-ROM, CD-ROM XA, MIXED MODE CD, CD-I, CD-I Bridge (Photo-CD, Video CD), Multisession CD (Photo-CD, CD-EXTRA, Portfolio, CD-R, CD-RW), CD-R, CD-RW, DVD-ROM (DVD-5, DVD-9, DVD-10, DVD-18), DVD-R, DVD-RW, DVD+R, DVD+RW. DVD-RAM, BD-ROM, BD-R, BD-RE
Supported media (write)
None
CD-R, CD-RW, DVD+R, DVD+RW, DVD-R, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM
CD-R, CD-RW, DVD+R, DVD+R DL, DVD+RW, DVD-R, DVD-R DL, DVD-RW, DVD-RAM, BD-R, BD-RE
Max media capacity (read)
8.5GB
8.5GB
50.0GB
50.0GB
Max media capacity (write)
8.5GB
8.5GB
50.0GB
Transport
Tray loading
Tray loading
Tray loading
Tray loading
Feature
Ethernet features
Power
management
Performance
features
Manageability
Interface1
PCI express 1.1 x 1 to fully support ASPM L0s/L1 and CLKREQ
NIC device driver name
Intel 82579LM/82579V ethernet network connection
note: |
Feature
Form factor
MDC 1.5 daughtercard
Power management
support
APM revision 1.2, ACPI
Approvals/Certifications
UL, CSA, NEMKO, CCIB, Industry Canada, FCC Part 68, CTR21, FCC Part 15 Class
B, Canadian ICES-003 Class B, C.I.S.P.R.22, Australian ACA, CE Mark, Other
Countries
Data mode capabilities
Optional symbol rates
Synchronous primary channel data signaling rates
Fax mode capabilities
Command set
Feature
HP un2430
EV-DO/HSPA mobile
Broadband module
HP hs2350 HSPA+ mobile
Broadband module
Technology/Operating
bands
Wireless protocol
standards
Wireless parametric
standards
Meets or exceeds TIA/EIA IS-98-D
Complies with 3GPP specifications
Maximum data rates
GPS
GPS bands
L1 - 1575.42 MHz
1575.42 MHz (± 1.023 MHz)
Maximum output power
Maximum power
consumption
2750 mA (peak); 1100 mA (average)
2000 mA (peak); 600 mA (average)
Power consumption, idle
not connected
20 mA
5 mA
Power management
Antenna type
Dual high efficiency 5 band antennae with spatial diversity, mounted in the
display enclosure
display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
11.5 g
<12 g
Dimensions (Length x
Width x Thickness)
51 x 30 x 5 mm (2.01 x 1.18 x 0.18 in)
Voltage, operating
3.3 V +/- 10%
3.3 V +/- 9%
Temperature, operating
(from TIA/EIA/IS-98-D)
Temperature, non-operating,
96 hours (from
MIL-STD 202 Method 108)
-40° to 85°C (-40° to 185°F)
-30° to 85°C (-22° to 185°F)
Humidity, non-operating
95% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
85% relative humidity for 48 hours @ 85°C (185°F) (non-condensing)
Configuration utilities
HP Connection Manager
LED activity
Feature
Intel Centrino Ultimate-N
6300
Intel Centrino Advanced-N 6205 (2 x 2)
Broadcom 43224AGN 802.11a/b/g/n (2 x 2)
Wireless LAN standards
Interoperability
Frequency band
2.4 GHz and 5 GHz
2.4 GHz and 5 GHz
2.4 GHz and 5 GHz
Antenna structure
NA
Data rates
Frequency support
NA
NA
Modulation
Security1
Sub-channels
Multinational support with frequency bands and channels compliant to local
regulations.
regulations.
regulations.
Media access protocol
CSMA/CA (Collision avoidance) with ACK
Network architecture models
Roaming
IEEE 802.11 compliant roaming between access points
IEEE 802.11 compliant roaming between 2.4 GHz band access points
Output power (for CCK and
OFDM)2
17 dBm typical
17 dBm max
Power consumption
Power management
Receiver sensitivity4
Antenna connections
3 U.FL type connectors, 50 ohm nominal impedance
2 U.FL type connectors, 50 ohm nominal impedance
High efficiency dual band antenna with spatial diversity, mounted in the
display enclosure.
Form factor
PCI-Express Half-MiniCard
3.4 g (0.0075 lb)
3.4 g (0.0075 lb)
6 g (0.013 lb)
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
4.75 x 26.65 x 30 mm (0.19 x 1.05 x 1.18 in)
Operating voltage
3.3 V +/- 9%
3.3 V +/- 9%
3.3 V +/- 10%
Temperature
Humidity
Altitude
LED activity
note: |
Feature
Bluetooth specification
4.0+EDR Compliant
Dimensions
30 x 6.5 x 3.25 mm (1.18 x 0.26 x 0.13 in)
Frequency band
2402 to 2480 MHz
Number of available
79 (1 MHz) available channels
Data rates and throughput
Transmit power
-1.5 dBm to 4 dBm (Bluetooth Class II)
Better than -20 dBM at 0.1% raw bit error rate
Power consumption
Antenna
Internally integrated within module
Range
Up 10 m (33 ft )
Electrical interface
Bluetooth software
Link topology
Security
Full support of Bluetooth Security Provisions
Power management
Microsoft Windows ACPI, and USB Bus Support
Self configurable to optimize power conservation in all operating modes, including Standby, Hold, Park, and Sniffx
Certifications
All necessary regulatory approvals for supported countries, including:
Temperature
Humidity
Altitude
Bluetooth profiles supported
Feature
Mobile voltage operation
3.0 - 3.6 V single supply
0° - 70°C (32° - 158°F)
Current consumption @ 3.3 V
High-rate image capture
Up to 240 image frames/sec
ESD resistance
IEC 61000-4-2 Level 4 (±15 KV)
Detection matrix
Feature
Audio
SRS Premium Sound PRO
Implementation:
IDT 92HD80 High Definition CODEC
Function key
volume controls:
Volume up, volume down
Mute button:
Volume mute button with LED indicator
Full duplex:
Yes
Microphone in: Stereo
Headphone/Line out:
Stereo
Integrated microphone:
Yes, dual digital microphone array
Audio output quality
Frequency response:
20 Hz - 20 kHz
Signal to noise ratio:
>85 dB
Total harmonic distortion:
0.01%
Noise floor:
-110 dB
Play/Record sampling rate(s):
8 kHz - 48 kHz
DAC:
16, 20 or 24-bit
ADC:
16 or 20-bit
Internal stereo speaker
Power rating:
2 Watts
Impedance:
4 ohms
Feature
HP 230-W Slim Smart AC adapter
HP 200-W slim smart AC adapter
Dimensions
20.0 x 10.0 x 4.0 cm (7.87 x 3.94 x 1.57 in)
17.0 x 8.5 x 3.5 cm (6.69 x 3.35 x 1.38 in)
1300 g (2.87 lb)
920 g (2.03 lb)
Input
100 to 240 V ac
100 to 240 V ac
Input efficiency
87% min at 115 V ac
87% min at 115 V ac
Input frequency range
47 to 63 Hz
47 to 63 Hz
Input AC current
Output
230 W
200 W
DC output voltage
19.5 V
19.5 V
Hold-up time
5 ms at 115 V ac input
Output current limit
<18 A, Over voltage protection- 29 V max automatic shutdown
<16 A, Over voltage protection- 29 V max automatic shutdown
Connector
3 pin/grounded, mates with interchangeable cords
Operating
temperature
0° to 40°C (32° to 104°F)
Non-operating (storage) temperature
-20° to 65°C (-4° to 149°F)
Altitude
0 to 3,048 m (0 to 10,000 ft)
Humidity
20% to 80%
20% to 80%
Storage humidity
10% to 90%
10% to 90%
EMI and safety
certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety
standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals -
C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B,
CCC, NOM-1 NYCE; MTBF- over 200,000 hours at 25°C ambient condition.
Feature
HP 8-cell Lithium-Ion Battery (83 WHr)
HP Long Life 8-cell Lithium-Ion Battery (75 WHr)
Optional HP BB09 Ultra Extended Life Notebook Battery (secondary battery)
Optional HP ST09 Extended Life Notebook Battery ("Travel Battery") (secondary battery)
Dimensions (H x W x L)
2 x 5.3 x 27 cm (0.8 x 2.1 x 10.6 in)
3 x 15 x 29 cm (1.2 x 5.9 x 11.4 in)
3 x 15.5 x 30.5 cm (1.2 x 6.1 x 12 in)
Weight (max)
0.442 kg (0.99lb)
0.442 kg (0.99lb)
.682kg (.1.5lb)
.550kg (1.2lb)
Cells/Type
Lithium-Ion
Lithium-Ion
Lithium-Ion polymer
Voltage
14.8 V
14.4 V
11.25 V
11.1 V
Amp-hour capacity
5.6 Ah
5.1 Ah
8.85 Ah
6.6 Ah
Watt-hour capacity
83 Wh
75 Wh
100 Wh
73 Wh
Operating temperature (Charging)
0° to 45°C (32° to 113°F)
Operating temperature (Discharging)
-10° to 50°C (14° to 122°F)
-10° to 60°C (14° to 140°F)
Non-operating temperature
-20° to 50°C (-4° to 122°F)
Battery re-charge time
Fuel gauge LED
No
No
No
Yes
1 year
3 year
1 year
1 year
Compatible with optional
travel battery
Yes
Yes
No
Yes
Feature
Dimensions (w x d x h)
37.4 (at front)/42.7 (at rear) x 416.5 x 272.7 mm (1.47 (at front)/1.68 (at rear) x 15.0 x 10.1 in)
note: |
Feature
Preinstalled:
Supported:
Certified:
Preinstalled software
Security software
Standard:
Optional:
Feature
115 V ac
230 V ac
100 V ac
Energy consumption
Normal operation
15.4 W
14.6 W
14.8 W
Sleep (Energy Star low
power mode)
0.98 W
1.03 W
0.98 W
Off
0.57 W
0.93 W
0.6 W
Heat dissipation1
Normal operation
53 BTU/hr
50 BTU/hr
51 BTU/hr
Sleep
3 BTU/hr
3 BTU/hr
3 BTU/hr
Off
2 BTU/hr
2 BTU/hr
2 BTU/hr
Declared noise emissions
(in accordance with
ISO 7779 and ISO 9296)
note: |
Feature
Eco-label certifications
This product has received or is in the process of being certified to the following approvals and may be labeled with one or more of these marks:
